power steering leaks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2012, 08:58 AM
I just got done installing new lines on my Mustang 2 rack and GM pump. I sprung a leak at the rack. The fittings have those o rings on them. Did I over tighten them? Is there anything better than those crappy o rings?
Old 10-16-2012, 01:01 PM
bigdog7373's Avatar
Of course it's fast
Did you lube the o rings?
You dont have to sit and crank the hell out of them, just get them tight.
Old 10-16-2012, 01:11 PM
they had some oil on them but I did basically do a full arm/body pull on the wrench as I laid underneath the POS.
Old 10-16-2012, 01:19 PM
bigdog7373's Avatar
Of course it's fast
Well there's your problem. You freaking crushed the hell out of them. Once you feel tension just give it one good snug and you're good.
The Following User Says Thank You to bigdog7373 For This Useful Post:
JOHNSHENOUDA (10-16-2012)
fittings leak, hose, power steering, rack
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
389 Standard Steering to Power Steering Fairlane67 Suspension - Brakes - Steering 5 08-29-2012 10:56 AM
power rack hose leaks jimd48chev Suspension - Brakes - Steering 4 12-28-2009 06:45 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 01:22 PM
