Power Steering Line - Custom Make - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2005, 07:20 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I need to have a custom length high pressure line made for my GM power steering. The local parts house is of no use. Where can I go to get the fittings I need, the hose and someone who knows how to operate the crimping machine?
Old 09-17-2005, 07:29 PM
Wiki Edits: 49
You might try an auto air conditioning shop. They use crimping machines on a daily basis. If you buy a hose longer than you need they might be able to shorten it and crimp on the new fittings.
Old 09-17-2005, 11:26 PM
The NAPA store in my town makes PS hoses....any length
Old 09-18-2005, 08:21 PM
Look in the yellow pages under hydraulic equipment repair or hydraulic supplies. A good hydraulic shop can make whatever you need.
Old 09-19-2005, 07:26 PM
hoses
I have purchased do it yourself kits in the past from a parts house. The hose comes in two parts, a hard line and the flexible line. Cut and bend the hard line, then tighten it into the special fitting on the flex line- a real heavy duty thing. Worked great. Bill
Power steering conversion 63 econo Suspension - Brakes - Steering 4 05-23-2005 06:32 PM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
Custom power steering/ air conditioning hoses: Source willys36@aol.com General Rodding Tech 4 04-05-2004 07:40 AM
Power Brakes for 52 chev car Looking for a steering box that will work Michael Bryan Suspension - Brakes - Steering 0 03-29-2004 07:22 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
