power steering lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2005, 05:03 PM
Slant3's Avatar
84 Mutt
Last journal entry: Steering column
On the back of a basic GM power steering pump, which line is the RETURN line ---on top or the one on the very bottom? Also has anybody used a filter for there ps line? If so what type of filter?
Thanks again Peeps
Old 09-22-2005, 05:32 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Thanks again Peeps
Well, what I would call the "run of the mill" GM (Saginaw) pump usually has one threaded (pressure) port and one hose-clamped (return) port.
Can you post a pic if this is not what you have?
Don
PS.
One idea for a filter, if you think it's nessecary, would be a remote-mount spin-on engine oil filter adapter. About he only thing that I recall seeing a filter on was an Eaton pump on a Ford Louisville 700 series grain truck.
Old 09-22-2005, 06:19 PM
Slant3's Avatar
84 Mutt
Thats the one . ...One threaded and one slip-on fitting. Thanks Don !!! I want to flush the entire system (pump and box) Thx again.
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
Power Steering conversion question / Bump Steer robin58 Suspension - Brakes - Steering 4 08-12-2005 09:02 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
gm power steering/ earls lines 6speedwagon Suspension - Brakes - Steering 3 02-17-2004 03:56 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
