Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power steering from long water pump to short water pump
Old 02-22-2004, 07:51 AM
poncho62's Avatar
poncho62 poncho62 is online now
Wiki Edits: 5
Both your PS and alternator would be on the same side. I'm not sure if they would interfere with each other.
You don't necessarily need the accessory hole to mount the alternator. You can make a bracket from angle iron extending from the front exhaust /header bolt.
Ontario Rodders
