Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power Steering Mounting Help
Old 03-12-2010, 08:24 PM
32Essex's Avatar
32Essex 32Essex is offline
Did you use the same pulleys that came off of the 4OO? Check the distance from the face of the balancer to a common spot on both engines like the machined boss for the pump to bolt on and see if they are different.
