Power Steering for my 53 Pontiac Chieftain - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2007, 06:18 PM
Hi I've a 53 Pontiac Chieftain that I want to add power steering to... does anyone know of a front end I could swap and bolt right in there or a power steering kit... its a 53 frame with a 77 400 motor... any help would be great
Thanks
Old 10-24-2007, 09:29 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Looks like two separate questions. I believe the typical 605 power steering box (or one of the upgrades) will bolt right in where your manual box is. biggest job would be cutting and mating your steering column, which is currently a solid shaft from the steering wheel to the worm gear. If your big motor doesn't allow room for a power box, Rack and Pinion is a possibility, but a lot more work, and "engineering".
For the other question, a bolt in front end upgrade, go to the crankshaft coalition icon and look up the wiki - 37 to 57 BOP (buick olds pontiac) suspension upgrade. Welcome to the world of BOP's
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
Power Steering conversion question / Bump Steer robin58 Suspension - Brakes - Steering 4 08-12-2005 09:02 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 07:06 AM
