which power steering port?
I am running a 69 lincoln 460 with a dodge omni power steering rack. Before I start cutting and bending lines, which port on the rack goes to the pump?..( i assume the other goes to the resevoir as a return?) please correct me if i am wrong...thanks
As a rule, the smaller port is the high pressure side. No guarantee though...
Russ |
does anyone know what the ports are on the dodge omni rack?..I was told that the pressure port maybe a 16mm 1.50 and the return was an 18mm 1.50...is this true?..and any thought as to where i can get the fittings to complete my steering?..added info...i went and ordered the pressure side line..it comes with a 16mm end and an 18mm end. the pump itself was listed as a16mm port...so it the pressure line goes into the pump with a 16mm then the other end that is an 18mm must be the pressure side on the rack...so the larger of the two is the pressure side...thanks anyways......ps rack is almost finsished being plumbed.( i am putting in a heidts adjustable pressure steering valve.The brackets for it are tacked in place and it looks good...
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Mustang/Maverick power steering | oldred | Suspension - Brakes - Steering | 4 | 11-04-2007 01:01 PM |
| Power steering whine/lack of assist question | '45 Ford | Suspension - Brakes - Steering | 7 | 07-05-2007 02:05 PM |
| 56 chev power steering | cols56 | Suspension - Brakes - Steering | 1 | 07-25-2005 05:06 AM |
| Unusual Power Steering Conversion | Lars Sorensen | Suspension - Brakes - Steering | 17 | 05-25-2004 02:05 PM |
