power steering pressure line leaking??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2010, 05:33 PM
briansansone's Avatar
4 chevys and a ford
Just replaced the power steering rack in my 2000 ford windstar.
The pressure line very quickly began to leak....bad.
I used the teflon seals that came with the new rack, heated them up per
the directions, and stretched them over the pressure and return fittings.
The pressure line wiggles even though it is really cranked down tight.
I went to Ford to get oem seals. Ford gave me two sizes??? but the send
and return are the same size. Am i missing something?? Should there be
two seals per fitting? Do I have a faulty lines?
This is making me nuts!
I need help Ford guys
Thanks
Old 09-22-2010, 12:00 AM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
you CRANKED down that fitting to tight and created the leak. fitting will swivel when tightened the correct way.
Old 09-22-2010, 09:19 AM
4 chevys and a ford
i did not crank down the fitting too tight. the threads on the rebuilt unit were damaged. but i sealed it all with teflon tape and thread sealer. rack is working fine now. beware of cheap and especially rebuilt parts.
Thanks for the reply though!
I posted another topic on this that chronicles all I went through with this
rebuilt rack. What a pain!
brian
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
power steering leak at the box 66musicmaster Suspension - Brakes - Steering 4 09-15-2009 09:00 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 09:20 PM
