power steering pressures - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2004, 05:17 AM
Question power steering pressures
Putting a mustang ll power steering rack in my '51 chevy pickup have 350 with a self contained '87 GM pump, Alan Grove 402L bracket, who makes a pressure regulating kit for the GM pump, someone said Mullins Steering who was purchased by Borgeson, (old part #1001?) I looked on their site don't see it listed. Any ideas? Zeke
Old 05-22-2004, 01:21 PM
I presently am running two mustang II power racks with a GM pump on each. One has the pressure reduced and one does not. The reduced pressure pump is slightly quieter, but that may be because it is a new pump and the other is a junk yard special. As for as driving performance, I can't tell a difference.
Trees
Old 05-23-2004, 04:42 PM
jalopy45's Avatar
Cool
There are 2 different racks. The earlier ones needed the pressure reduced so they did not blow the seals and were slowed down a bit , where the newer ones could use the pressure. After you know which rack you have if you still need to reduce the pressure R.B.'s has a new valve for the back side to the pump that works great. I think Heidts makes an inline adjustable valve.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
