power steering problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2009, 07:00 AM
I have a 79' dodge cb300 van, and I had to take out the steering box to fix the upper shaft seal. After I installed the steering box, I jacked the front end up, started the engine, turned right-to-left to bleed the system, but when I drive it, it turns to the left pretty easy, but real stiff going to the right. The system also is a brake hydro-boost for the power brakes, that works with the power steering if that helps. Has anybody had the same problem?
Old 02-12-2009, 09:48 AM
you may have to turn it to the right hard and shut off motor .
let set 30 min to let air out .take cap off reservoir .
repeat a few times .check fluid for air bubbles foam .
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
Power steering question chrisflock Suspension - Brakes - Steering 4 02-19-2006 02:31 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
power steering problem Doug Renton Suspension - Brakes - Steering 2 12-03-2002 11:24 AM
