Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power steering problem
Old 01-13-2003, 01:26 AM
nelsonauto nelsonauto is offline
Post Power steering problem
Installed 76 mustang 2 rack ( removable pinion houseing, I believe this is the Ford model)The pump is a GM I reduce valve pressure using 4 shims. Started engine and turn steering wheel, dam near took my hand off, Steering wheel whiped back and forth.If there is to be a check valve in line where does it go? The pressure line is a inverted flare fitting at rack( they both are ).Thanks for any info.
