Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power steering problem
Old 01-13-2003, 03:26 AM
aka Duke of URL
Are you sure you have pressure and return at the spool valve installed correctly (backwards) and as for the shimming, do you have the required pressure specs and check the final pressure with a quality gauge?
Is this a fresh rack or take-out?
