Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power steering problems
Old 03-02-2012, 07:47 PM
Cape Cod Bob's Avatar
Cape Cod Bob Cape Cod Bob is offline
Before starting , did you crank the wheel lock to lock several times with fluid in and then recheck fluid level so that you get everything filled? Also do this after starting and everything is OK, and recheck fluid level. If that don't work, be sure that you have the pressurre side to the proper inlet on the rack.
