Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power steering problems
Old 03-04-2012, 08:03 PM
enjenjo enjenjo is offline
If it's the linkage type power steering, if the control valve is too tight it will do this. there has to be a bit of clearance, about 1/8" each way for the valve to work properly. If it's indeed a power rack from a Tbird, the lines at the rack are reversed.
