power steering pulley - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2003, 01:22 AM
New Member
Post power steering pulley
this might sound like a dumb question but how do you install the pulley on a '79 chevy power steering pump. It has an allen head in the end of the shaft. I need to change the pump but I don't want to take it off until I know how to install the pulley on the next pump.
Thanks
Old 05-19-2003, 01:43 AM
DoubleVision's Avatar
Post
the pulley is a press on, pull off job, and as i already learned, when pulling one, get the right tool, i tried to 2 jaw and it only rounds off the lip. when reinstalling one, you can do this little trick, stick the pump in a freezer a few hours, then take the pulley and heat it with a torch, take the pump out of the freezer when you get the pulley hot enough, then slip it on the shaft, you can use a rubber mallet to press it back on this way. seen a friend of mine do it like this and it worked pretty good.
Old 05-20-2003, 10:33 AM
bullheimer's Avatar
NEVER use credit cards!
Post
here's my installation trick. let the place where you bought the pump do it for you. they will generally do it for free. i bent the crap out of mine (but i didnt doit per the above either).
Old 02-11-2004, 09:50 AM
78514Ford's Avatar
New Member
powersteering pully
You can buy a tool to take off and install the pulleys for around $80.00 at napa or snap-on etc. They work really well.
