power steering pulley question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 02:33 PM
Hi
I'm asking this for a friend who is having some problems----he has a sbc with PS he had a long WP set-up and is now going to a short WP because of clearance problems with a thicker radiator. he bought a swp mounting bracket for the PS pump ,but the pulleys are of about 1/4 " .What I want to know is does the swp setup require a different ps pump pulley than the lwp setup?
thanks
Old 04-06-2009, 03:52 PM
fast68's Avatar
likes chevy trucks & boobies
SWP and lwp had totally different pullies and also power steering brackets and pumps
he is to make a hybrid of two different styles/era of gm setups work he needs to pick one or the other style and get a complete setup together, for everything
the old swp setups had the alt on the driver side
just plain all different than lwp setups in 69-up cars and 73-up trucks
good luck
Old 04-06-2009, 06:34 PM
MorrisonLC's Avatar
You can shim the PS pump forward pretty easy if you want to use the newer ones. Easier than swapping pulleys. Or fab a new bracket.
Old 04-06-2009, 06:44 PM
he bought a new bracket, but the ps pulley is out too far it needs to go back toward the engine,thats why we were wondering if with a swp if the ps pump maybe takes a different pulley-he has the old style saginaw pump and this bracket JEGS #555-60702
Old 04-06-2009, 07:02 PM
MorrisonLC's Avatar
Yeah, that's a problem. I went and got a 3-groove pulley and put the PS on the outer groove so I could shim it out. I got that Jeg's bracket too and welded little tube sections to it to extend it about 1/2" from the block.
Old 04-06-2009, 09:06 PM
thats good to know--the ps pulley he has now has a double pulley and he has a triple on the crank,so I guess we could shim it out and use the inner pulley on the pump to the outer pulley on the crank.---we were trying to get the outer pulley on the pump to align with the middle,or outer on the crank.---might be neater looking if he gets a single for the pump
Old 04-06-2009, 09:31 PM
MorrisonLC's Avatar
Or you could get one of those serpentine kits and make it all new, but that's pricey. I just like to stick with home-made shade-tree fab and it usually all holds together. I did make up a little tensioner device out of a turnbuckle for the PS bracket because standing out from the block the way I made it, it was too flexible and I couldn't tighten the belt good enough.
Old 04-07-2009, 07:43 AM
did U also have to put some washers between the pump and the bracket? that little bulge on the back of the pump seems to be in the way.
Old 04-07-2009, 08:09 AM
MorrisonLC's Avatar
No, on my pump the bulge fits right into the cut-out area of the bracket. I wonder if you a different pump. But I imagine washers wouldn't hurt anything as long as you got long enough bolts.
Old 04-07-2009, 10:19 AM
where did you install the turnbuckle?
Old 04-07-2009, 02:34 PM
MorrisonLC's Avatar
Outboard corner of that PS bracket (the Jegs one) and the other end on the motor mount. Makes a triangle and stiffens the whole thing up considerably.
Old 04-07-2009, 04:07 PM
Morrison LC,
thank you very much,you've been very helpful.
Gary
Old 04-07-2009, 06:48 PM
MorrisonLC's Avatar
Glad someone appreciates my DIY, homemade approach (I h8 chrome)
All the best!
Power Steering hose question jdvega64 Suspension - Brakes - Steering 4 08-15-2008 07:27 AM
Question on 66 Mercury Comet steering and brake issues....... onebadmerc Suspension - Brakes - Steering 5 01-11-2007 05:41 PM
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 06:00 PM
Power steering hose, restrictor Question Joe 570 Suspension - Brakes - Steering 1 02-02-2006 07:03 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
