Power Steering Pulley, SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2010, 06:13 PM
Sinister's Avatar
Power steering pulley on a '69 Chevy C-20, 350 SBC with AC. Are the PS pulleys different with air conditioning compared to non-air? I replaced my PS pump and pulley and the new pulley lines up where my AC compressor belt would go on the crank pulley. It needs to come out a notch if I'm ever going to run AC. Do to being a ******* I no longer have the old pulley which was bent anyways.
Old 06-23-2010, 07:05 PM
DoubleVision's Avatar
Is it the short water pump system or long water pump? both systems were different. 1969 was the year GM abandoned the short leg pumps other than for the corvette which were used well into the 80`s. Then they did something even dumber with the long system by adding the air compressor on the drivers side of the vehicle so it added clutter everywhere. If your truck came with a short pump system and you used pieces from the long the pulley`s won`t line up.
Old 06-23-2010, 07:10 PM
Sinister's Avatar
It's a short water pump. I believe GM used short pumps a little later on the trucks. The pulley I bought was just some generic chrome one from Summit. I'm not throwing the belt now cruising down the freeway, but I would like to step up to AC at some point.
Cadillac Power Steering guts question rwruther Suspension - Brakes - Steering 5 11-17-2009 11:31 AM
5.7 hemi power steering pulley removal? xpsyclonex2002 Engine 2 11-10-2009 02:27 PM
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
Power steering pump pulley Ktaves1971 Engine 1 05-18-2004 09:47 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
