power steering pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2003, 10:41 AM
Question power steering pump
i have a 65 chevy impala.the hose going to the power steering pump leaks.ive tighting down to small claps on it but it doesnt help.i cant figure out why if i have to claps on the hose going into the pump why it would still leak out between the hose and the tube that the hose goes on to the pump? any help would be appreciated.
Old 02-15-2003, 11:21 AM
aka Duke of URL
Arrow
I *** -u-me that you are talking about the return line here. Is the hose fresh (recently replaced and not hard) and is it the correct diameter? Are you using band clamps or worm clamps? Worm clamps will sometimes cut the hose leading to this type of leak.
Old 02-15-2003, 02:10 PM
milner's Avatar
Post
kultulz said it all,just make sure the silver solder joint on the back of the pump is not cracked and making it look like its leaking at the hose. good luck!
Old 02-15-2003, 05:00 PM
Question
lol.thanks.im not sure what im talking about anymore ethier.ill get under the car again and look.maybe it is the tube coming from the pump and not the hose.
