Power steering pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2011, 02:15 PM
BBC BBC is offline
Help Identifying Power steering pump
Could you guys please take a look at the pics and let me know what type of PSP I should be searching or asking for, I can find lots of pumps out there but no real joy finding my exact one, it's on a 454 and has the remote reservoir...found this on Ebay from CPP, but then they describe it as a reservoir, odd as it looks just like my pump and nothing like my reservoir.
http://cgi.ebay.com/ebaymotors/1969-...Q5fAccessories
Thanks in advance.
ID:	57532   Click image for larger version
ID:	57533   Click image for larger version
Old 08-14-2011, 05:50 PM
It's a standard GM pump, just the cover is different. You see that style on big block motorhomes. You can take most any GM pump, and put that cover on it.
Old 08-14-2011, 05:52 PM
LATECH's Avatar
It is the reservoir for the pump. It is also referred to as the "can" for the pump. It looks very correct if the one in the E Bay photo is of the one you will recieve. If you look a little closer you will see the large tube sticking from the top of the can, for a remote reservoir.The remote has a hose that drops down and clamps on to the bigger tube of the "can" (or reservoir) . essentially yours has 2 reservoirs.One contains the pump and the remote for easy access for maintenance .
Old 08-14-2011, 06:13 PM
BBC BBC is offline
Thanks Latech
I didn't realise that it was a pump & reservoir combined, but why can't I find my exact pump if it's a standard GM model as enjenjo says?
Appart from the Ebay one this is about as close as I can find...
http://www.summitracing.com/parts/AAZ-20-7923/?rtype=10
Old 08-14-2011, 06:56 PM
LATECH's Avatar
The actual pump part inside is the same , pulleys are different, cans are different for each application. You pumps can has a hose for a remote reservoir.
The canister you are looking at has no pump in it. You will need to pull it apart and put the pump part in the new canister.
The cardone unit from summit(that you posted ) looks correct, but you will still need to pull and re install the pulley.
Old 08-15-2011, 12:05 AM
this is the pump you need http://www.rockauto.com/catalog/moreinfo.php?pk=1787196
Old 08-15-2011, 01:52 AM
BBC BBC is offline
Thanks for your help guys...it's really appreciated.
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
power steering pump help, please steve t Suspension - Brakes - Steering 3 08-15-2008 05:50 PM
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 03:02 PM
power steering pump baumholder19 Suspension - Brakes - Steering 2 04-09-2006 10:53 AM
power steering pump help billyr Suspension - Brakes - Steering 1 02-06-2004 09:20 PM
