Power steering pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2011, 01:19 PM
Power steering pump
Happy Thankgiving everyone I need to know how to bleed my GM power steering pump please. Thanks Vito
Old 11-24-2011, 03:21 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Usually all you have to do is after filling it up is turn the wheel lock to lock,
which means turn it all the way to the left as far as you can and then turn to the right as far as you can, do this like 4 or 5 times or more and it should get the air out. JMO
There are some other way's if this don't work but you need to try this first.
Cole
Old 11-24-2011, 04:42 PM
Cape Cod Bob's Avatar
Be sure to add more fluid after that.
Then start er up and do it again with the wheels off the ground and able to go LtL.
Once the air is out should not shudder. It may do that when first started.
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
hot power steering pump, steve t Suspension - Brakes - Steering 4 10-07-2008 05:36 PM
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 03:02 PM
power steering pump help billyr Suspension - Brakes - Steering 1 02-06-2004 09:20 PM
power steering pump joser63 Suspension - Brakes - Steering 1 01-30-2004 10:34 PM
