Are all GM 60s & 70s power steering pumps pulleys press on ? I have to change out pump mounting bracket which requires me to remove the the pulley. the donor bracket has a different type pump and pulley, units are from a 350 oldsmobile engine
A lot of 70's GM's used keyed pulleys on their pumps.
Occasionally I've ended up keeping the tools I borrowed under AutoZone's free loaner program, if I thought I'd use them often, and they worked well. In this case I figured I might only rarely use the pulley puller, so took it back.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
