Power Steering Pump Avalability?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2009, 09:50 AM
I have a 1965 Plymouth Belvedere II, 273 V 8 engine, auto transmission, power steering, no power brakes.
The power steering pump started making some noise and the seal is leaking. When I tried to find a replacement at several of the better known auto parts stores, they had a listing on the pump with photos, but when I tried to order it they told me the pump was no longer available.
Does any one know where I can get a rebuilt power steering pump for this car?
The book lists two. I need the one that has the return fitting (about 1/2 inch in diameter) right beside the fill mouth of the reservoir (about 2 inches in diameter).
Also, if worst comes to worse, can I plug up the holes where the hoses go on the steering sector, and just drive the car with manual steering?
Old 02-05-2009, 09:59 AM
DoubleVision's Avatar
Maybe this will help, not sure but thought I`d try.
http://www.autopartswarehouse.com/de...QA1206159.html
Old 02-05-2009, 10:02 AM
SSedan64's Avatar
Rock Auto has it without the reservoir, with the Res. it's a return & rebuild only. They do have rebuild & seal kits so you could use your Res.
http://www.rockauto.com/catalog/raframecatalog.php
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 01:14 AM
power steering pump question 46 chevy pickup Suspension - Brakes - Steering 7 08-25-2006 07:05 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
