Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power steering pump on blown motor
Old 05-11-2008, 06:51 PM
darkostoj darkostoj is offline
Originally Posted by Marcus
Your's is closer than mine I think you can use an inset pulley like the one I ordered and it might work or you can use a double pulley on the power steering pulley...the problem sucks though and can't believe this issue hasn't been addressed by B&M or Wiend etc.
what kind of brackets are you using? I'm using brackets off a 67-68 camaro with a 302/350...they also work with a 8" balancer that I have.
These are the similar brackets here
where did you get your inset pulley?
from what i gathered there was another crank pulley that bolted onto the stock 2groove crank pulley and thats what the p/s used...but its impossible to use that peice since the blower pulley is there. With the 3 grooves at the crank the one nearest the motor was for the alt, the next for a/c, and the 3rd for p/s
