Power steering pump Failure? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2009, 08:15 AM
I was running my car pretty hard the other night (74' Monte Carlo, Turbocharged) I wasn't turning a huge amount of RPM's or anything and when I got home, I stopped in the alley opened my garage and drove it in. The second I shut the car off I hear this sound like somebody's peeing on the floor.
I popped the hood and the inside of the power steering pulley is wet and there is fluid running out onto the garage floor. I walked outside and just where it sat running for a minute or so while I opened the garage was dry! The steering never acted funny or made any noise either. Just emptied itself of fluid the minute I shut off the engine. What gives?
Has anyone else just had a major dump of fluid out of the pump like this? could it be much more than just a blown seal? I am going to purchase a rebuild kit and tackle it myself. But I have never seen a leak like this before ever from a GM steering pump.
Old 05-26-2009, 08:46 AM
83SILVRADO's Avatar
GROUND POUNDER
i dont think it could be much more than a blown seal. that sounds about right to me. but i am no expert. i would go ahead with what you said with the repair kit. good luck.
Old 05-29-2009, 06:42 AM
Yup, A little more than a blown seal....
I pulled the pump and the pulley and noticed the shaft had about .015"-.030" axial play in the shaft. Killed the seal. I took the pump apart and went to the auto parts store. They didnt sell a rebuilt kit at my local NAPA or they were too lazy to look it up.
The store offered the pump or the pump with resivoir. I bought the pump only and with core returned it was $37.00
I put it together last night and one of the mounting points was not the same as the original and I had to make a spacer to get the belts to line up correctly.
Never is anything a direct bolt on anymore it seems.
The bushing or bearing was toast, bad. If I would have just put a new seal in it would have gone bad very quickly.
lwp swp power steering pump bracketry dirtinla Suspension - Brakes - Steering 6 01-01-2009 10:02 AM
power steering pump help, please steve t Suspension - Brakes - Steering 3 08-15-2008 05:50 PM
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
