power steering pump help, please - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2008, 04:22 PM
steve t's Avatar
ex biker, now hotrodder
i have a 61 chevy impala power steering pump that i unscrewed supply line fitting at bottom of pump, spring & plunger fell out, now i don't know how to reassemble, which way does plunger fit, with the little nut going in 1st & seating on spring, with flat spot on plunger showing after install? any help will be appreciated
Old 08-15-2008, 04:55 PM
Yes, you have it correctly. Spring in first, then the end of the piston with the nut. Be sure it is VERY clean when you install it.
Old 08-15-2008, 05:02 PM
Holder350's Avatar
Auto Parts Professional
http://www.corvette-restoration.com/...mp_rebuild.htm
Old 08-15-2008, 05:50 PM
steve t's Avatar
thanks both of you , a great tech with pictures,
Power steering pump on blown motor Marcus Engine 14 05-16-2008 01:10 AM
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 01:14 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
