Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power Steering Pump I.D.
Old 03-23-2002, 10:27 PM
From the discription you have given sounds like the pump you have is a mid 60's version. Some of these pumps also had an aeroquipt style pressure fitting instead of the more common inverted flare.My daily driver is a 65'chevy which has this same pump. Most of the drive pulleys on this style of pump were larger than the press on style.I think GM quit using this pump on the small blocks when they went to the long water pump on passenger cars but it use may have continued on the trucks as late as 1970. Oh! I almost forgot to give you some part #'s..GM5693129 was popular as was #7800515 &#5698072-paulweldit
[ March 24, 2002: Message edited by: PAULWELDIT ]
[ March 24, 2002: Message edited by: PAULWELDIT ]</p>
