Power steering pump for Jag - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2007, 05:44 PM
Would anyone know if the power steering pump on the 85 350 Covette engine will run with the 79 XJ6 Jaguar power steering rack?
Cheers Bruce
Old 03-02-2007, 11:55 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Any power steering pump can be used with any power steering gear. Try the GM pump and if it is too goosey, get a pressure reducing valve from a hot rod parts store. These valves replace the pressure regulator in the GM pump and were made for use w/ the Mustang II rack which doesn't need the pressure the stock GM pump supplies.
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 01:14 AM
power steering pump question 46 chevy pickup Suspension - Brakes - Steering 7 08-25-2006 07:05 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Power Steering pump pressures Jag Daddy Engine 5 06-19-2003 12:15 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
