power steering pump mounting help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2007, 07:36 PM
i have a 68 chevelle with a 454 the prob is that the alt is mounted on the driver side head the power steering pump bracket is mounted on the block under the alt. when i try to put the power steering pump in the pump hit the steering gear box i need to know what brackets to use to make the power steering pump fit. i have a short water pump . please help this is my first engine swap and i am almost finished .can't wait to hear the sweet sound of my 454. thanks in advanced.
Old 04-08-2007, 08:30 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Motorchrome has some ALT mounting brackets for SWP/LWP on a BBC.
You may have to swap your ALT over to passenger side (LWP) in order to mount a PS pump. That likelely means using different pulleys as well.
My Journal (see entry #41) has pics of their pulleys and brackets on my 454.
1971 chevy 350 power steering pump colincamaro Suspension - Brakes - Steering 10 12-27-2006 02:14 AM
power steering pump question 46 chevy pickup Suspension - Brakes - Steering 7 08-25-2006 08:05 PM
1989 Silverado Power Steering Pump Canadian Charlie Suspension - Brakes - Steering 3 05-16-2006 02:28 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 08:22 PM
Power Steering pump pressures Jag Daddy Engine 5 06-19-2003 01:15 PM
