power steering pump pulley play - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2012, 07:08 PM
On a dodge power steering (2000) pump how much play on the pulley (in and out) is acceptable?
If it's too much could it be the cause of a chronic serpentine belt "chirping" issue. Note ther are no leaks.
Old 02-12-2012, 07:21 PM
LATECH's Avatar
Probably wont cause belt chirp. It will just find its "center" and run there.
Most likely the belt is the issue or the tensioner isnt holding enough tension. Take a look at the belt alignment across the pulley setup. one of them is bound to be crooked, indicative of a worn bearing, allowing the belt to slide across, or as I said a weak tensioner.
You may need to drop the belt and spin all the pulleys to see if one is loose/sagging from bearing wear/ or possibly trying to freeze up, wich could also cause a noise.
The Belt on my F 150 was 1 year old, was a good brand name belt, and it started making some noise,drove me nuts because it only did it at a certain time(60 mph) which made it tough to nail down,it wasnt real loud, but I listen to noises for a living, it drove me nuts. Put on a new belt and it has been good.
Old 02-13-2012, 07:17 PM
belt chirp
This serpentine belt chirp has been bugging the H outta me for about 2 years.
Pretty sure it's chirp and not slip.
Replaced all idlers checked for pulley play, cleaned all surfaces multiple times, gone through many belts which all look fine , but end up chirping in < 1k miles
The only pulley that has any play in it is really the PS pulley , ~.125 " of in and out. Just purchased a Dayco laser alignment tool , hoping to see what may be just enough out of alignment.
chevy power steering pump pulley 65ELCMO Engine 3 06-04-2010 08:19 PM
power steering pump pulley question? hemi joe Suspension - Brakes - Steering 2 02-18-2010 12:07 PM
90s SBC Power Steering Pump pulley Removal Help Mustangsaly Engine 12 10-08-2006 07:00 PM
Power steering pump pulley purportedly multipurpose? wickedwitchinak Suspension - Brakes - Steering 6 08-07-2006 12:18 PM
Power steering pump pulley Ktaves1971 Engine 1 05-18-2004 10:47 PM
