Power steering pump pulley purportedly multipurpose? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2006, 01:02 AM
Is it a problem to presume that people who peddle power steering pulleys are proficient in their preferred profession, particularly when proclaiming that press-fit pulleys and their more prolific counterparts are perfectly interchangeable? In short, some guy on Ebay mentioned that the keyway style pulley he is selling can be pressed onto a non-keyway style pump without issue. Is this true?
Thanks in advance for your help.
Megan
Old 08-06-2006, 07:31 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I think he is wrong, wrong, wrong.
The keyed pulleys are tapered and are not really "press fit" but a "taper fit"
The pulleys that press on are just that--"press fit"--they are press to the shaft and you are ready to roll
The keyed pulleys are secured with a nut on the end of the shaft.
Bryan
Old 08-06-2006, 12:07 PM
That is what I thought, but I wasn't sure. So a second question, where oh where can I find a press fit one? I swear I've googled every possible synonym for and combination of "press power steering pulley" to no avail. Any suggestions?
Old 08-06-2006, 12:13 PM
Bryan59EC's Avatar
I have not seen these in the aftermarket--(not saying they are not there).
Check your local Chevrolet store or a salvage yard---mid 70's to late 80's I think---and old pickup would be a good donor-
I don't know if there are single groove out there--the two groove acts kind of like an idler for the ALT or AC (depending what you have hanging on the left side)
Bryan
Old 08-06-2006, 12:34 PM
DOUBLEDICK's Avatar
JEGS has chrome press on pulleys $29.99 GM power steering pulleys key way and press fit part #865-44853 in my catalog.Hope that helps.
Old 08-07-2006, 06:00 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
That is very alliterative!
I had a similar problem and got a pulley for an 87 Chevy pickup, it is press fit.
Old 08-07-2006, 11:18 AM
I found one at the salvage yard. Thanks for all the help!
Power Steering Help WEIRD 71gtx Suspension - Brakes - Steering 1 07-18-2005 07:15 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
need help picking brackets for alternator, power steering pump kellyem Engine 0 02-13-2004 08:54 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
