power steering pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2006, 07:48 PM
46 chevy pickup's Avatar
46 chevy pickup
HI ALL
The GM power steering pump quit pumping.
I have a GM pump on mustang II rack.
The pump I have has a pressure valve.
I did not know the year the pump was so I bought a 77 pump.
The pump is the same all but ,when I removed the line fitting there was no pressure valve.
My question is what years did the pump have the pressure valve?
I need the valve so I can reduce the pressure.
The steering is a little sensitive.
THANKS BOBBY
Old 08-22-2006, 10:39 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Use your old one. It unscrews from the pump body.
Old 08-23-2006, 01:57 PM
46 chevy pickup
power steering pump ?
Thanks for the reply johsongrass1,
I removed the line fitting and tried to install valve,but hole under the fitting is not deep enough
BOBBY
Old 08-24-2006, 08:54 AM
Take the pressure valve off the new pump and stretch the spring inside it to reduce pressure. Reinstall. If the pressure is too low, than place a 4mm washer under hte spring to increase the tension. Or just install a spring of choice.
If that doesn't work then I need a picture.
Old 08-24-2006, 06:52 PM
46 chevy pickup
power steering pump?
Johnsongrass1
I removed the line fitting from the rebuild pump and there is no pressure valve under the fitting.
Bobby
Old 08-25-2006, 08:41 AM
You have nothing that looks this?
Flow control valve
Old 08-25-2006, 06:56 PM
46 chevy pickup
JOHNSONGRASS1
problem soved ,traded pump at napa for another pump,same number.
This pump has a pressure valve.
I thank you for your help.
Old 08-25-2006, 07:05 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Hey JG, that was some good info, Thanks
I will store that for further use.
Now I can ID all the old parts I have around here for GM pumps
Thanks again.
46, which Rack do you have, how many turns from lock to lock, that will make a difference on how sensitive it is also.
1989 Silverado Power Steering Pump Canadian Charlie Suspension - Brakes - Steering 3 05-16-2006 01:28 PM
power steering pump pully 49dream Suspension - Brakes - Steering 2 04-01-2006 06:41 PM
Mustang 2 Power steering pump nugget Suspension - Brakes - Steering 1 10-05-2004 12:57 AM
Power or non-power steering is the question RAW Suspension - Brakes - Steering 2 09-23-2003 05:32 AM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
