Power Steering Pump SBC BBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2010, 02:41 PM
454headache's Avatar
Are the power steering pumps for small block and big block Chevrolets interchangeable?
As in, can I use a pump from a say 91 5.7 on a 454 if I just change the brackets?
Old 04-22-2010, 11:53 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Yes, The brackets are different, but the pumps should be the same BB & SB.
Rich
Old 04-26-2010, 10:23 AM
bullheimer's Avatar
NEVER use credit cards!
that is a major understatement Richard. there are so many f'ing brackets, not just to the block but from bracket to pump mainly, it will drive you crazy ESPECIALLY if you put them all together first before you try to get the bracket on the pump and AFTER you press the pulley on the pump. wonder what those idiots (engineers) were thinking. ps, don't know what rig your runnin but if its a truck with large tires you NEED a double pully
Old 04-26-2010, 03:21 PM
fast68's Avatar
likes chevy trucks & boobies
bbc and sbc ones not same at all
and then on top of that there are different ones for with a/c or without a/c and so on
also the little triangle bracket that bolts to the exhaust bolt there were two different ones of those in same years even some used a stud and others used a bolt
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 03:02 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 10:09 AM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 06:48 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 05:00 PM
