power steering pump for sbc with MustangII power rac - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2006, 05:02 PM
Last journal entry: dash mods
I have a sbc and a TCI Mustange 11 IFS, what power steering pumps are best to use.I know the GM pump can be doctored to lower pressure, but is anything else better.Someone told me a Toyota pump will work fine.Most everyone I talk to says they can't feel the steering with power.
thanks, Cisco
Old 11-06-2006, 08:21 PM
Wiki Edits: 49
By far the easiest way to go is the GM pump with an adjustable pressure valve from Heidts.
This will allow you to pretty much "dial in" the feel and sensitivity you want.
Old 11-06-2006, 08:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Just about any pump will work with any gear. The GM pump is way overkill (even for GM gears!) but with the pressure regulators like Centerline shows it will work great. I like to get the tiny pumps off foreign cars for obvious reasons. Very compact, can have remote or attached reservoirs and come already pressure regulated.
Old 10-05-2011, 11:13 PM
old street rodder
have a mustang2 suspension in a 34 dodge ,and am using a mid 60's chrysler p/s pump which works great right off the shelf
Old 10-06-2011, 01:59 PM
35terraplane's Avatar
Mustang II
thanks, Cisco
Which rack do you have, if it is off one of the T-Birds, you can use a gm pump without the valve. They are the same rack speedway sells. being able to adjust them like centerline said would be nice though.
Bob
Old 12-29-2012, 06:39 PM
I am running a G M pump with my Mustang 2 P S rack. I found an article in an older rod magasine telling how to adjust the pressures down to be compatable. I can,t remember which mag it was but it gave shim sizes and how much each would reduce pressure. I think it was Hot Rod magasine . I followed their procedure and my steering is fine on the road. I have good road feel and no PS leaks. I,ll try and find the book and post the article as soon as i can shake this lousy cold i,ve got.
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 08:22 PM
Power Steering pump pressures Jag Daddy Engine 5 06-19-2003 01:15 PM
Lean backfire Camaro76 Engine 5 04-15-2003 06:45 PM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 10:03 PM
power steering pump impala dreaming Suspension - Brakes - Steering 3 02-15-2003 06:00 PM
