power steering question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2009, 07:37 PM
slammed 57's Avatar
Last journal entry: t
I have a 57 chevy truck with a mustang ii front end and manual mustang ii rack. well its time to switch to power steering, question is sould i go with a mustand ii power rack or a t-bird power rack, which is better and why, also what pump should i use, i know theres a few choices, i have a sbc if that makes any differnce, thank you , mike
Old 10-26-2009, 08:59 PM
S10xGN's Avatar
Gotta love a turbo!
Unless you want to refab your mounting brackets, stick with the MII rack. IIRC, the T-Bird's bolt spacing is different...
Russ
Old 10-27-2009, 05:22 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
power steering
RE: Gm power steering pump with a mustang rack................
I dont have the specs handy, but from memory, GM pumps can put out 1300+ psi, and mustang racks only take about 750. There are kits from borgeson, or separate reducing valves you can use to match them up.
Disclaimer. Old guys suffer from CRS (can't remember sh...) so the specs could be wrong, but you definetly need to check it out.
Old 10-28-2009, 09:34 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Hmmm ...
Some (late 70's, early 80's?) Fords were factory equipped with Saginaw power steering pumps (same as Chevy)
Also following the "CRS rule", though ... I can't recall if they used a Ford or a Saginaw power steering box.
Old 10-28-2009, 02:35 PM
I'd want to compare the racks for of shaft, tie rods and joints. etc size and therefore strength, as I suspect the beautiful and popular '57 Chevrolet truck weighs considerably more than a pi**- ant Mushtang II. Ooops, am I displaying a bias there?
Old 10-28-2009, 04:09 PM
66GMC's Avatar
As a bit of a follow-up to my last post:
78 Thunder-chicken with a 302 for an application.
PUMPS:
It appears that the Ford "C3" style
pump with the plastic reservoir was standard, and that the
Saginaw
pump was used in the "Extra Duty" application.
BOXES:
They list both Ford
and
Saginaw
power steering boxes for that 78 t-Bird application as well, which leads me to believe that the pump and gear need to match.
It has been suggested on other threads that perhaps different relief valves are available, as well as adapter fittings (from 45 SAE flare to Metric O-ring) are available through some of the custom hot-rod shops ... but I have never had anything to do with that situation.
Old 12-02-2009, 05:42 PM
ogre's Avatar
the 'Duracell Project'
there is a good thread on power racks here
Old 12-02-2009, 06:43 PM
Speedway has an off set bushing so the Tbird rack will fit the Mustang II mount.
You use Mustang II tie rod ends with the Tbird rack on a Mustang II suspension.
Mustang II tie rod ends are functionally the same size as GM tie rod ends.
Omni/Horizon used a Saginaw pump with a reduced pressure with their rack.
The Tbird rack is a bit slower that the Mustang II rack, so is less sensitive.
Mustang II ball joints are bigger than GM ball joints.
Chevy AD truck steering column question mr52pickup Suspension - Brakes - Steering 1 10-24-2008 07:45 PM
MII Power Steering question v8muscle Suspension - Brakes - Steering 0 07-16-2008 02:40 PM
Steering box question Ratoflic Suspension - Brakes - Steering 1 04-27-2005 04:14 AM
Dumb Power Steering Question... Mike_82 Suspension - Brakes - Steering 1 03-28-2005 11:43 AM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 10:50 AM
