Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - power steering rack in a 34 ford frame
Old 08-14-2009, 04:43 PM
ajbcc2's Avatar
ajbcc2 ajbcc2 is offline
Last journal entry: frankenstude too
hmmm.. cross steering still has bumpsteer as you say..but it sounds like you are saying that a panhard will eliminate bumpsteer..I dont believe that because a panhard as you know,only prevents side movement of the axle which does prevent steering direction change ,but,not the up and down of the suspension travel...which I think will still allow bumpsteer because the short tierod or the longer cross steering rod on a vega box do not pivot at the same point as the axle which is the center of the spring therfore still allowing tire direction change..again I agree with you its simple geometry.
