Power steering rack question
Hoping someone here can answer an oddball question. I'm using a 1988 Corvette power steering rack on my project. Would it be possible to separate the aluminum valve body/pinion carrier steel tube extension and rotate them 90* relative to their original positions? The pipes that normally enter the steel tube at the top are really getting in the way of other components. It would be great to rotate them to the front for more clearance.
[SIZE=2]http://i17.photobucket.com/albums/b5...on-rebuild.jpg[/SIZE] [/SIZE][/SIZE][/FONT] |
When I have problems like you are having I go with braided stainless lines.They flex and can be routed as necessary.Good luck
The problem I'm having is the rack needs to be as close up against a component as possible. Where the connections enter the rack is the problem.
Since I asked this question I received an answer on another forum I'll share in case this comes up for someone else. One this rack, anyway, there are two shiny "buttons" protruding through the steel tube 180* apart at the junction point. These position the steel tube to the aluminum housing. They can be pulled out with vice grips with a slight turning motion. There is apparently an "O" ring seal in there, so the tube can then be rotated to any angle. Then redrill two small holes and lightly hammer the positioning buttons back in place. Finis! |
| All times are GMT -6. The time now is 06:33 AM. |
