Steering box.
I have just been through what you are talking about on a 67 Mustang coupe . I dont know what your box looks like but if its similar to a 67 then the following "StangerSite . com" © 2008 was exactly what i was looking for. The box had a worm and sector shaft with the adjustment carefully set to a specified torque before you tighten down the lock nut on the adjusting screw. The screw on the Mustang box lifts the sector shaft up or pushes it down depending on which way you turn it. Mine was done out of the car on the bench with everything disconnected. If the steering is too stiff in the Mustang box the info. tells me the sector shaft and worm will be scored. (metal to metal draqgging)
Cheers. P.s. Google came up with plenty of info. in my case. Maybe you will be lucky. Cheers. Al. Last edited by 67Mustang Al.; 07-23-2009 at 08:24 AM. |
on most boxes if it needs this adsjustment then the box is worn past is life time and it is not recommended to do this to them, especially if there is server slop over around a 1/8 or 1/6 steering wheel turn on a power box anyways
if you turn the screw down too far then the steering will get stuck in the center position you should try to locate a betetr condition box rather than trying to adjust the wear out of the one you have for safety sake but not everyone will agree or understand good luck! |
guess I kinda knew that in the back of my mind, kinda hoping for 'easy fix' ! Going to be hard to find ... a good sector for '85 ????????? Maybe they used them for a lot of years ? Problem is , I built this car (customized '48 Dodge ) from the ground up , was a lot working room near the sector, til I put the motor in and fenders on !!!!......thanks.....Do you guys know how mant years Chrysler used the same sector ?
Finding sector shaft
Well the steering box in the 67 mustang has one long steering shaft which makes removal out through the firewall extremely difficult with the motor in so i know what you are saying. Bugga.!!!!
I am not familiar with the chrysler stuff, maybe Fast 68 will know, or try and google "Chrysler steering box" on the search page and see what you get. Maybe easier to buy a reconditioned box as some are saying once the clearances become too great between the sector and worm it is time to throw it as new parts would be similar to the price of a new or reco. box.?????Cheers good luck Al. |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Mustang/Maverick power steering | oldred | Suspension - Brakes - Steering | 4 | 11-04-2007 01:01 PM |
| Power steering whine/lack of assist question | '45 Ford | Suspension - Brakes - Steering | 7 | 07-05-2007 02:05 PM |
| power steering won't return to center | powerrodsmike | Suspension - Brakes - Steering | 32 | 10-12-2006 08:22 AM |
| Power steering question | chrisflock | Suspension - Brakes - Steering | 4 | 02-19-2006 02:31 PM |
