Power steering self bleeding?
Is the power steering system (pump, plumbing, and steering box) self bleeding? Assuming all the fluid has been removed from the system, is there a specific procedure to recharge the system or do you just start dumping in fluid and then fire up the pump?
Dewey
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
IMO I would fill the pump tank up with fluid and the without the engine running (you may want to jack up the front wheels this makes it a lot easier to do) turn the wheels lock to lock many times and recheck the fluid. This way is much easier on the P/S Pump. Then start engine and lock to lock again and recheck fluid. It may take a few miles of driving before the pump stops making noise (depending on what type of pump it is). You just want to drive air out and fluid in, this method works very well.
Steve
Thanks Steve and smallblocker,
Sounds like something even I can accomplish.
| new power steering pump questions | HARVICKx29 | Suspension - Brakes - Steering | 3 | 09-05-2005 03:22 PM |
| Power steering pump hitting box | tjh211 | Suspension - Brakes - Steering | 7 | 11-16-2004 04:29 PM |
| Unusual Power Steering Conversion | Lars Sorensen | Suspension - Brakes - Steering | 17 | 05-25-2004 02:05 PM |
| Power Steering Pump Problem... | IWasBlown | Engine | 1 | 04-07-2003 09:03 PM |
| anyone know anything about putting power brakes and power steering on a '63 impala SS | Benni520 | Suspension - Brakes - Steering | 0 | 10-14-2002 01:22 PM |
