Power Steering Set-Up Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2005, 09:00 PM
I have a 1950 Hudson Coupe which should get a 'Stang II hub-to-hub from Fatmans with the power rack & pinion fairly soon. I plan to put a 95 vette LT1 full drop-in engine (all wiring, accessories including power steering pump) in it. Anyone see any problems just hooking the vette power steering lines to the new rack? Or, are there any modifications to be made first?
Thanks......Jay
Old 10-15-2005, 09:22 AM
willys36@aol.com's Avatar
Wiki Edits: 21
No biggie, that is done all the time. Only probelm is that GM pumps put out too much pressure and you wil have goosey steering so get one of those little $39 pressure reducing valves all the rod parts houses sell made specifically for this application.
It slips easily into the high pressure outlet port in the back of the pump and will match the pum to the rack.
Another fix is to get one of Heidt's $80 adjustable pressure regulators. Either way, no biggie.
Old 10-15-2005, 10:24 PM
Thanks willys36, sounds like the ticket! I'll find one.
Jay
Old 10-16-2005, 09:23 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Jay
I believe he is correct. Doesn't FatMans give you that information for their rack?
Power Steering 1955 Chevy willy6576 Introduce Yourself 1 10-27-2004 11:05 AM
50's Chevy truckw w/ power steering ? Slickriffs Suspension - Brakes - Steering 3 10-13-2004 05:18 PM
350 Chevy power steering Neophyte Suspension - Brakes - Steering 2 09-21-2004 12:07 PM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 02:54 PM
power steering fluid andybird Transmission - Rearend 1 12-11-2002 12:12 PM
