power steering, sprays fluid out the vent whole on reservoir cap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2011, 11:41 AM
I just joined so hope i'm doing this right, I have a 38 dodge street rod with a 350cu. in 375horse radical cam, with powersteering, problem, It keeps blowing fluid out the top of the reservior, have bleed the reservoir, filled reservoir half full, and reservoir has a check val. in bottom of it , run line with tee into over flow line, so it would circulate back into the system. Has anyone had this problem,or do you know what I can do to correct it. Colt 45
Old 05-31-2011, 06:59 PM
I know you said you bled the steering line, but you might want to bleed it again. I had a similar problem on an old 84 Ford F150, it was creating pressure in the reservoir and the fluid looked like it was "boiling." The fluid was rolling over etc.
I completely drained the lines and reservoir then refilled it with fluid. I spent extra time turning the steering wheel lock to lock until the steering pump quit whining. It was cured.
Old 06-02-2011, 06:38 AM
power steering problem
thanks for your help i'll try it and bring you up to date again thanks ace's an 8's/ colt 45
Dumb question - reservoir cap vent required? AntnyL Suspension - Brakes - Steering 3 08-07-2009 10:11 PM
power steering fluid douger456 Suspension - Brakes - Steering 1 01-22-2008 08:02 PM
Hot power steering fluid RAW Suspension - Brakes - Steering 8 04-26-2007 10:00 PM
ATF vs Power Steering Fluid? Jag Daddy Engine 1 12-15-2003 12:22 PM
Remote reservoir power steering V8 S-10 Suspension - Brakes - Steering 1 09-17-2003 05:51 PM
