Power steering swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2007, 11:27 AM
Power steering swap
Hi Gang I have a 1979 chevy donor van I wish to install the power steering parts on my stock 1955 2nd seric pickup, is this doable? also any chance the front disc will swap or should I look at a kit fro cpp or alike that has the valving correct and the under cab master cylinder
does anyone know if van bodys are of any value or shall I get some plasma cutting practice
Any thoughts
Thanks B
Old 11-13-2007, 03:40 PM
Years ago ... I made a plate that bolted to the stock steering box plate and adapted it to a mid 60's GM power steering box. Then I used the PS pump from the same vehicle ... worked great.
I would imagine with a little skill and a lot of imagination ... the same thing would work with the van box and pump.
As for the brakes ... ( remember this was in the 70's ) ... I just installed a set of 54 Chevrolet passenger car hubs and drums. Bolted right on ... no modifications. The 54 Chevy hubs and drums were the standard 5 lug Chevrolet pattern.
NOW ... If I wanted discs ... I would most likely buy the kit.
Old 11-19-2007, 07:47 AM
Thanks Deuce, I looked at the cpp book and they have one for a pick up truck , and could not tell me if it would work from a van? do you have any idea why it would not work ?
Thanks Bo
Old 11-19-2007, 08:03 AM
31 five window
Last journal entry: grill and rear end
Cut the roof out the van somebody can use it to fill their roof on an older rod.
Old 11-19-2007, 08:08 AM
its in Prince frederick Maryland and its free, glad to help anyone out!, as I have been helped here!
56 chev power steering cols56 Suspension - Brakes - Steering 1 07-25-2005 06:06 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 10:50 AM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 08:06 AM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 07:56 PM
