Power steering temp - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2003, 11:49 PM
root's Avatar
New Member
Power steering temp
Hey wazup,I install a 350 in my 95 Toy and went with a type 2 power steering pump,my question is how hot should the fluid get,I check it with my temp gun and it is around 135 to 140 in the aluminum res.I installed a small oil cooler up front with radiator,I check cooler on return and it is around 115.Im not to sure what kind of temps I should be looking at.Like I said the temp at aluminun res stays around 140.Any help on this would be great.Thanks
350 Yota
