Power Steering Troubles 48'ford drop top - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2011, 09:16 PM
I am working on a 48' ford convertable with a 70's 301ci gm small block, turbo 350 trans, ford 9" rear and buick steering column. I have a ps sector box off a 65 gallaxy 500 which i have bolted in there (space is tight around the headers), and a ps pump for the 70's gm small block. From what i can find my pressure and flow rates are compatable enough but when i crank it and start to turn the wheel the wheel begins to jerk back and forth until i shut it off. The system was bled according to instruction for the steering gear and it is a new rebuilt gear and pump. the lines are not backwards. ANY IDEAS would be WONDERFUL!!!!!
Old 06-18-2011, 10:02 AM
S10xGN's Avatar
Gotta love a turbo!
That happened to my LS-1/Maverick swap. The GM pump puts out too much flow (or pressure?) for the Ford rack. I installed a 2 GPM flow reducer into the pump outlet and that cured it. I don't know if these reducers are available for the old style pumps like you have, but Heidt's has an adjustable reducer that taps into the lines that would work for any situation.
I was gonna link it, but Heidt's site s%cks, it's part number PS-101...
Russ
Old 06-18-2011, 05:27 PM
Thanks
Thanks for the tip i will see if i can make that work! does you think summit might have it in stock as the lady wants the car done and i have to drive 5 hours to work on it each time
Old 06-19-2011, 10:45 AM
S10xGN's Avatar
Gotta love a turbo!
Well, Summit shows they in stock...
Russ
power glide rebuilt troubles amature Transmission - Rearend 5 12-26-2009 07:36 PM
solid drop front steering ??? rocwal Suspension - Brakes - Steering 1 10-30-2007 09:03 PM
installed low power stereo, now the car stutters when RPM's drop Dizturbed One Electrical 5 06-15-2005 04:34 PM
86 suburban steering troubles fantasy77 Suspension - Brakes - Steering 3 10-28-2003 10:29 PM
anyone know anything about putting power brakes and power steering on a '63 impala SS Benni520 Suspension - Brakes - Steering 0 10-14-2002 02:22 PM
