power steering unit on a chevy 5.7 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2009, 02:22 PM
Just replaced a power steering unit and am getting what it sounds like the belt rubbing on the side of the pulley. Is the belt to loose? How do I bleed the air from the lines? The vehicle is a 1987 chevy suburban 5.7 engine. Originally the power steering unit had a pulley that had two grooves when I ordered the part the guy ended up getting a single groove pulley. I am curious if I could still run my ac with a single pulley? Here is how I attempted to bleed the air from the lines after installation. I left the cap off of the container that holds the power steering fluid and slowly turned my wheels to the left and then to the right. I did not have the vehicle jacked up. Is this the proper procedure to bleed the air?
Tommy
Old 05-26-2009, 03:31 PM
I don't know if this will work, but I'm going to try and attach a copy of general instructions that came with my hoses.
ssmonty
Name:	pwr steering inst (Small).jpg
Old 05-26-2009, 03:50 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you have no specs, tighten until there is about 3/4" deflection when pressed in the middle of the longest run with your thumb, using moderate pressure.
As long as the pulleys all line up, but if all your accessories are being run off the one belt, it may have a shorter than usual life and may need tightened more often.
Yes, the cap doesn't need to be left off, though. Don't peg the wheel left or right very hard, and not for very long, either. Refill as needed.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Power Steering For A '49 Chevy Truck? carsavvycook Suspension - Brakes - Steering 7 05-09-2009 06:03 PM
SF oil???? n-gin Engine 6 07-09-2008 01:37 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
