Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Power steering whine/lack of assist question
Old 07-05-2007, 09:50 AM
pepi's Avatar
pepi pepi is offline
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Originally Posted by cboy
How does one determine if there is air in the system? I recently had to replace the hose from the pump to the box. Is there some sort of air bleeding proceedure that should have been done?
yes turn the steering lock to lock and bumping the wheel with the steering wheel against the lock a couple of times with the engine running that will clean the air up, you may have to do that more the once. if the noise came after the repair bets are on air in the system
