power steering, without power - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2008, 12:51 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Local high school has a "dune buggy" project going. It has a power steering box (GM front end) with no pump attached (VW motor in the back).
When I mentioned it, they said they were just going to plug the fittings.
It was an open house, so I just let it go, but it bothered me.
Will that work? How will the pump get lubrication?
Old 02-25-2008, 01:17 PM
Re:power Steering
Hi it will work, the power steering pump is a helper pump, but they can't plug the fittings the will have to loop them(lock up if plugged) l had a cousin once cheap out and do that this way, went for years that way TROY
Old 02-26-2008, 08:31 AM
powerrodsmike's Avatar
Wiki Edits: 161
It will kind of work but, as Troy said they need to loop the ports together with a length of hose. For lubrication they need to put power steering fluid in it.
Now the problem as I see it is that the steering box will now be a pump, with the internal piston moving fluid through the steering box and loop hose with every turn. This problem will be compounded by the fact that a power box is a higher ratio box to begin with. Just seems like a huge waste of energy to me. Steering should be as easy as possible, especially on a dune buggy. Turning the wheels past obstructions found on trails requires ALOT of effort...(I know this to be true, my 73 blazer came stock with manual steering.. )
Later, mikey
BE different....ACT normal.
Old 02-26-2008, 09:23 AM
oldguy829's Avatar
Wiki Edits: 88
power steering without power
kind of what I was thinking Mikey. Mostly, it's a fabrication project for a fair, so it probably won't be judged on the automotive merits (Its an awesome looking project modeled after one of the chase vehicles in Road Warrior), But the son of an aquaintance wants to buy it after it's done, and I'd like to give them a heads up on possible issues.
Thanks for the feedback.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Mustang/Maverick power steering oldred Suspension - Brakes - Steering 4 11-04-2007 01:01 PM
Power steering whine/lack of assist question '45 Ford Suspension - Brakes - Steering 7 07-05-2007 02:05 PM
power steering won't return to center powerrodsmike Suspension - Brakes - Steering 32 10-12-2006 08:22 AM
Power steering question chrisflock Suspension - Brakes - Steering 4 02-19-2006 02:31 PM
