Power sterring pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2006, 06:55 PM
willowbilly3's Avatar
Last journal entry: Body mods
I am putting a Chevy Astro steering box on my rpu and I need a compact pump. I found several with remote reservoirs but all were on cars with rack and pinion. I am wondering if there is a common junkyard compact, remote reservoir pump that would be compatible with a saginaw box.
Old 07-27-2006, 10:53 AM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
p/s pump
Try a 86 Chevrolet 4cyl S10 pump. It has a remote reservoir and uses a gearbox.
Old 07-27-2006, 04:04 PM
Thanks. I will try just that.2wd or 4x4?
Old 07-27-2006, 04:38 PM
russlaferrera
Wiki Edits: 2
p/s pump
I have a 86 ,S10,2wd. so I know for sure. I think they maybe all the same. Plus you have a couple of years to gather from 84 -90 ? Hope this helps.... Russ
Old 07-27-2006, 06:02 PM
I have one off an 86 chevy van. Not sure if you would call it "compact"
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
Power steering/snow plow pump jrm123180 General Rodding Tech 1 08-19-2004 07:59 AM
Help! How do I install a new power steering canister to my existing pump? boricua_stang Suspension - Brakes - Steering 1 10-02-2003 06:48 PM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-03-2003 11:20 PM
700r4 Front Pump Question ChevyCam Transmission - Rearend 13 03-15-2003 07:23 PM
