power train swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2013, 07:28 PM
power train swap
Hi installing 2000 S10 drive line in a 1926 REO 4 door the old rear end was
center in the frame the S10 is off center by an inch or so I will have to carry it through with the motor mounts any hints
Old 08-29-2013, 09:08 PM
BOBCRMAN@aol.com's Avatar
No, minor offsets are the norm on modern drivetrains. Look at just about any Ford rear wheel drive built since 55.
My stock Dodge Dakota delivery truck has the engine offset over three inches.
Old 08-30-2013, 08:30 AM
Why?
The U-joints can't tell if the offset is up-and-down or side-to-side. Put the rear axle where it needs to be. Put the engine/trans where it needs to be. Build a driveshaft to fit between the two. Just be sure that the trans output shaft and rear axle pinion shaft are PARALLEL. They don't need to be in line in either axis. All you have to look out for is tunnel clearance and total U-joint angle.
1950 Chevy drive train swap questions okiechev Hotrodding Basics 1 03-01-2012 05:50 AM
powerglide gear train swap out questions transman08 Transmission - Rearend 1 10-05-2010 07:27 PM
Drive Train Swap GERRY F Engine 2 07-02-2010 01:34 PM
Power steering swap Chesapeake Suspension - Brakes - Steering 4 11-19-2007 07:08 AM
Power steering swap on a g-body Scuzzy Suspension - Brakes - Steering 0 08-08-2003 11:07 PM
