Power-Trax no slip system - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2002, 08:08 PM
Post Power-Trax no slip system
Hi. I'm looking to put a Power-trax system in my r73 Elky rear end. Anybody have any information on these systems? Thanks.
Old 09-14-2002, 10:59 PM
NAIRB's Avatar
Post
I've installed a couple of these units and to date, they have worked well. It's a snap to install them, they just replace your spider gears in the diff, just follow the simple instructions. These things give you a positive lock on both rear wheels under hard acceleration, they do clank, or click when you turn corners however.A good product that works and is affordable.
Old 09-15-2002, 03:29 AM
hotrodit's Avatar
Talking
I'll second that! great bit of kit & easy to install, if you search on the net powertrax.com there's plenty of info & step by step intallations by some private webs with good results.
Old 09-15-2002, 07:52 AM
Smile
Thanks for the reply! I have another question, posed by my son. If a higher stall torque converter is installed, what happens to your ability to "creep" down the road at low RPM, quietly? We live in a town where the least hi revs or exhaust noise immeadiately draws the attention of the laws. So do you have to increase the RPMs/ noise level, and ride the brakes to keep your car moving from street light to street light? His concern is being stopped frequently for this. I wasn't sure how to answer him.
Old 09-15-2002, 08:00 AM
NAIRB's Avatar
Post
You will have to rev the car more to get it to move, the more stall speed the worse it will be. If you are light on the throttle, it will move a little, it's not like the converter won't work at all until it's approx stall speed, but the looser it is, the worse it will be. I had a 383 chevelle with a powerglide, 4.56s, and 4500 stall speed, and believe me, you could here the engine when you cruised away. Go to the drags, and watch cars cruise down the return lane, that will give you an idea.
Old 09-17-2002, 08:07 AM
Post
I had a 3000 stall in my 68 with small block 350 and as long as you were light on the gas you didnt know it was there if you are looking for street and strip theres no need for any thing over 2500-3000 stall!!
Old 09-17-2002, 03:22 PM
F-1Rodder's Avatar
Post
I use a 2000 stall behind my 383. It engages immediately when put into gear and and it will idle coasting as with any transmission/converter. However it will flash up to a higher rpm without engaging fully so that if the brake pedal is held down and you wind it up, it does not fully engage full power until 2000 rpm. So in this case it is not difficult to drive. If your stall speed is above normaly highway drive speed, then the converter slips. This isn't good because it generates heat and causes problems with transmission over-heating. So if you have a car which is going to be driven primarily on the street, you want just enough stall to utilize the cam shaft characteristics. If you just want to race the car, then a high stall converter would give the most powerful launches because the starting point sill deliver immediate torque multiplication to the drive line.
You have to think of the cam, intake, timing and stall speed as joint contributors to driveability. A car with a big cam and no stall elevation is going to be lugged down and will not get moving. Generally, it is a poor idea to over-cam a street car for this reason.
Old 09-17-2002, 03:27 PM
F-1Rodder's Avatar
Post
Oh yes....the Powertrax No Slip is a good product. I get a little chirp from the inside tire on a street corner if I apply too much gas or take the corner too tight. But it greatly improved the driveability of my F-1 pickup because I do not slip one tire all the time which was the case before....I could hardly back up a hill in my own driveway without it. It is very well designed and has very few wearable parts. It physically uncouples and does not have slip plates to wear out. If you are going to buy one, call the company directly and you can order it for $275 from the factory (see their website). Don't go through a distributor.
Old 09-18-2002, 07:07 AM
Post
Thank you for all the help! This is a 73 Elky,SB 350, stock 8. pistons, stock alum. Weiland manifold, Isky mega cam-270dur. 465 lift, big valve heads,TH400 and stock exhaust (for now), headers soon.
I'm thinking a B&M "Traveler",900-2100 stall. My son wants it "zippy", but I'd like for him to pass a FEW gas stations at least!!
