Power Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 03:38 PM
ggevaert's Avatar
Power Valve
Hi,
Is the power valve system and subsequent fuel delivery strictly affected by vacuum?
Holley's website recommends keeping the number low to ensure the powervalve does not kick in at idle but I didn't think power valve's came into play at all in the idle circuit?
Thanks
Gary
Old 06-02-2013, 06:47 PM
ggevaert's Avatar
power valce
Thank You F-BIRD'88,
When I ran through the testing here is what I came up with:
@ 35 mph steady drive (1700 rpm), flat road - 17 hg
@ 50 mph steady drive (2100 rpm), flat road - 16 hg
@ 65 mph steady drive (3000 rpm), flat road - 13 hg
In park idling - 14
In drive idling - bounces between 9 and 14
Accelerating agressively (but not WOT), ie. to over take a car from going 50 mph - 10 hg
so my first thought was that I should go with a 11 PV to a) give me more power when overtaking and b) that this is 2 below the 13 I'm getting so about correct.
The odd thing is that quickfuel only provides, at the highest a 10.5, so 11 is out of the question; next you are saying I need to actually go lower to a 4.5.
So, my question is; is a PV only intended to be for WOT additional power or also for heavy acceleration?
I think I need to do some more runs and include grades in these to see where the vacuum level is then.
Gary
Old 06-02-2013, 06:54 PM
Richiehd's Avatar
JS-70
You want to go with1/2 of whatever your lowest vacuum is . In your case a 4.5 will work fine for you. Higher and valve will open creating a rich condition at idle.
power valve caps turbolover Engine 5 09-21-2010 05:55 PM
power valve 406MOUSE Engine 3 04-30-2010 12:41 PM
Power Valve? StevenC Engine 1 01-20-2006 09:01 AM
Power Valve or Not? jrm123180 Engine 13 10-14-2004 08:35 AM
Power Valve 2wld4u Engine 13 08-16-2003 07:21 AM
